Reverse Gauges
Whats up everybody do anyone have instruction on how to install the el glow reverse gauges in correctly.
Hey no one know the instruction on how to do this.
Didn't it come with instructions? Might consider contacting the mfgr.
It should be pretty straight forward install. Do you mean you need instructions as to how to remove everything to pull the gauge cluster out?
take your gauge cluster apart and put the el glow gauge on top of the OEM ones and connect the wires
all you'll need is a #2 phillips screwdriver and somewhere to keep all the screws. Just remember not to overtighten the screws when reassembling the dash, so as not to crack/break the plastic.
But like tmv said, it's fairly basic. Just overlay and connect the wires to the supplied transformer and find a place to put the switch. |
