ZDriver.com
-   300ZX (Z32) Appearance Exterior, Interior (https://www.zdriver.com/forums/300zx-z32-appearance-exterior-interior-50/)
-   -   The HIDs are On. (https://www.zdriver.com/forums/300zx-z32-appearance-exterior-interior-50/hids-25139/)
Darkmann Mar 4, 2008 07:59 PM
The HIDs are On.
It was a very warm day today so at lunch time I decided to install the HIDs. See the pics for yourself. They lighting is definitely way more bright than the OEM's. However, the light pattern is sub par - I can see the dark areas caused by "light shadows" as the patters criss-cross between the left and right lamps. Also notice that the retrofit doesn't show the characteristic inverted "L" of OEM HIDs. I drove around a few streets tonight and no one flashed me. So I suppose I'm not bothering oncoming traffic. My guess is that the retrofit is fine. I think the issue is that the design of the OEM lens doesn't allow the HID beam to scatter like OEM non-HID would. Just like NismoPick said - we get what we pay for!!! I'll ride as is because I see a lot better with these on. I have 8000K bulbs and would try them on just for looks!!!
Before HID Install (Bimmer on left, Z32 on right). I'm standing, maybe 8-10 feet from both cars
http://i274.photobucket.com/albums/j...w/IMGP0936.jpg
After HID Install - the Z gets much brighter, and actually mimmicks the Bimmer.
http://i274.photobucket.com/albums/j...w/IMGP0954.jpg
Z on Left (note how better sharply defined the Bimmer's pattern is)
http://i274.photobucket.com/albums/j...w/IMGP0950.jpg
Closer Shot - the Ghostly bluish pattern on far right is from the Z's lights - the scatter goes that far right!!
http://i274.photobucket.com/albums/j...w/IMGP0951.jpg
tonsoffun300zx Mar 4, 2008 08:01 PM
cool looks great!
Barry'Z(NJ) Mar 4, 2008 08:14 PM
Your results are typical.
Though judging from the comparison, you could adjust the Z headlights up just a bit.
Darkmann Mar 4, 2008 08:21 PM
That's good to hear. The headlights are aimed correctly per Maryland requirements and I actually see great when driving.
Barry'Z(NJ) Mar 10, 2008 06:53 PM
Well here's mine for comparison, I'm only talking a couple inches up at the current distance...
http://zcon.photodump.org/files/12/100_1879.JPG
Darkmann Mar 11, 2008 04:21 PM
See what you mean Barry. I'll raise mine up a few inches.
Also, I took my pics standing outside. I wonder if that'll make any difference at all. I assume that your garage door is the standard door, thus we can use the lower slats as reference.
KasbeKZ Mar 11, 2008 04:37 PM
you'd get better range if you aimed them up just a tiny bit. looking good though.
Barry'Z(NJ) Mar 17, 2008 07:44 PM
Yes, with the car about 25 feet from the door, bring the low side cut-off to, or just above, the lowest break/hinge.
domsgarage Apr 3, 2008 04:57 PM
I put HIDS in a while ago, they always look so good.
