hidden fan??
hidden fan??
hey guys another question for youz.
on your tbar right by the personal lights, there is a little fan that i find to be a lil too noisey.. it turns on automatically with the ignition i think. is it supposed to be loud and what exactly is it for??
Which fan are u refering too? There are three fans that i know of on these cars? There is one that is mounted in front of your a/c condensor and is automatic, it comes on whenever u turn a/c on or if the engine temp reacts 105 defrees C. I know b/c my dumbass had my fingers in it workin on it when my TT's engine temp reacted that temp. The otherfan is mechanical, it is the one hooked to ur water pump and runs full time. Your last fan is the one on the inside of the cabin, its the one that pushes around the air on the inside of ur car. I m not sure if i understood which one ur referring too, let me know which one it actually is.
ya its inside the cabin where the map lights are i pulled that panel off cause those map lights are not working. and there is a tiny fan sppinning when the ignition is on.. its loud .. i take it yours isn't
i pulled that panel and removed two screws and i saw this thing spinning and it is making a sound of a house fan sort of,, that need to be fixed .. pull off that panel and u will see two screws holding this black thing into place . turn on the ignition and look at it ull see it spinning??
that's the temp sensor for the auto climate controls
if it's making noise just lubricate the fan with some all purpose household oil.
not wd-40, won't last long enough and you'll hafta do it again when it dries up.
yeah, everyone should have a bottle of 3 in 1. that stuff is great, my skateboard bearings were froze nearly solid, i put a little 3 in 1 on them and spun them a bit and they were almost like new. and it doesnt evaporate quick like wd 40, keeps em lubricated.
