Head light fix...need some help
Old Mar 17, 2005 | 11:53 PM
nka04a's Avatar
Well guys as some of you may alrady know my headlight brackets are busted. The other night I was tring to get the whole assimbly out to fix it with some JB weld of something because I cant afford to get all new headlights. so could anyone tell me how I should go about taking everything out that is involved with the headlights? If you could give me a step by step that would be awesome. Thanks guys, N8
Old Mar 18, 2005 | 12:03 AM
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
There are two bolts and two nuts on each headlight assembly to take out. The two in the back are kinda hard to get to as there isn't much room. Also you will have to remove your fascia.
Old Mar 18, 2005 | 11:41 AM
nka04a's Avatar
How do I remove the fascia......is it hard?
Old Mar 18, 2005 | 01:34 PM
DanZ32's Avatar
Dan's the Man
If you have replaced the stock airbox with a cone filter, you can access the screws and bolts as follows.
Remove the front centre panel
Remove the filter and mafs and t-tube
-you will now be able to access and remove the inside bolt and nut from each housing (nut is up front, bolt is towards the engine).
If you remove the turn signal housing you will easily be able to access the nut closest to the outside of the car for both lights.
If you remove the 3 screws on the wheel well and bent that back, you should be able to access the last bolt. (these ones are the pigs of them all and a bigger pain to put them back in afterwards).
Good luck and take you're time.
Old Mar 18, 2005 | 04:00 PM
nka04a's Avatar
Thanks guys im gonna try to tackel it this weekend ill keep you posted
Pipsqueak
Mar 13, 2013 10:52 AM
Beaneriser
Jul 6, 2011 02:30 PM
skittle
Feb 16, 2007 04:07 PM
calvinD
Feb 26, 2004 06:26 PM
CatchinZs
Sep 1, 2003 10:07 PM
