Door window trim piece
have a 1993 300zx convertible. Need to replace the door window trim piece that contains a slot for the slider. Looks like the trim piece is held in place by 4 push pin clips located under the vertical gasket at back of door window. can this piece be replaced without removing the inside door panel and inside pillar trin piece which holds the seat belt?
Mike Phillips
Oct 1, 2021 12:34 PM
oldmanrodz
Feb 15, 2013 12:17 PM
