Z31 engine problem
Old Jan 20, 2010 | 06:52 AM
acastiaux2's Avatar
Z31 engine problem
I hold the accelerator down and this is what it does and it also takes a long time to idle down when it is running right http://www.youtube.com/watch?v=EOBn0...=youtube_gdata
Old Jan 20, 2010 | 07:05 AM
Run the ecu diagnostic test & write down the codes.
Old Jan 20, 2010 | 07:15 AM
acastiaux2's Avatar
I have nothin could cause this
Old Jan 20, 2010 | 07:42 AM
couldyourephrasethat
I'm not sure what you mean.... Is this a statement or question?
Old Jan 20, 2010 | 07:45 AM
Would this be the same problem from a year ago? https://www.zdriver.com/forums/300zx-z31-forums-8/1985-engine-cuts-out-28426/
Old Jan 20, 2010 | 08:42 AM
acastiaux2's Avatar
No it's not the same problem and it was a statement when I get home I'll post what codes showed up
Old Jan 20, 2010 | 02:06 PM
z31rider's Avatar
It seems that its the MAF. Pull that off and see if the wires aren't broken. If they are then, buy another. You can get cheap off ebay but they are used... i paid over 250 for mine at checker auto parts. I even have a spare in my tool box in case it goes out again that i got a junkyard for 6 bucks
Old Jan 20, 2010 | 06:11 PM
acastiaux2's Avatar
I'm almost positive it's not the maf because when I unplug it it runs even worse and if the maf was bad and I unplugged it it shouldn't change anything right?
nismowolf
Mar 29, 2014 04:40 PM
thxone
Jun 15, 2006 07:19 PM
Adz260
Apr 28, 2003 04:59 PM
Dec 16, 2002 07:18 AM
kolts
Oct 21, 2002 01:50 AM
