Z31 engine problem
I hold the accelerator down and this is what it does and it also takes a long time to idle down when it is running right http://www.youtube.com/watch?v=EOBn0...=youtube_gdata
Run the ecu diagnostic test & write down the codes.
I have nothin could cause this
Originally Posted by acastiaux2
(Post 274298)
I'm not sure what you mean.... Is this a statement or question? |
Would this be the same problem from a year ago? https://www.zdriver.com/forums/300zx-z31-forums-8/1985-engine-cuts-out-28426/
No it's not the same problem and it was a statement when I get home I'll post what codes showed up
It seems that its the MAF. Pull that off and see if the wires aren't broken. If they are then, buy another. You can get cheap off ebay but they are used... i paid over 250 for mine at checker auto parts. I even have a spare in my tool box in case it goes out again that i got a junkyard for 6 bucks
I'm almost positive it's not the maf because when I unplug it it runs even worse and if the maf was bad and I unplugged it it shouldn't change anything right?
| All times are GMT -7. The time now is 12:46 AM. |
