What turbo with stock internals?
Old Oct 16, 2005 | 09:34 AM
Loktai's Avatar
This has probably been posted before or I could probably research it abit but it might be a quick question, so here goes.
We're dropping a VG30ET into a car which is currently VG30E, and while the turbo engine is out we wanted to do basic maintenece and also upgrade the turbo. We planned on using stock internals, and this car will be driven on the street, but we also wanted a good bit of power out of it. What do you guys recommend for a turbo? I dont have much exepreince with nissans mostly mazdas so I am kind of clueless so forgive me if its been gone over countless times. Any suggestions?
Charles
Old Oct 16, 2005 | 09:52 AM
Velox ZX's Avatar
From: I'm located in the more southern local... Jackson, MS.
Garrett T3 turbo. You'll need to upgrade to a T3/T4 hybrid if you're looking for real power. You'd do better off using aftermarket blow off/pop-off valves, and an aftermarket wastegate. Keep in mind.. the pop-off valve is built into the intake manifold (to my understanding, but then again I don't have a turbo model Z). So, you might want to convert to a N/T manifold, or have Engloid fab one for you. These are the best places I can send you for your needs. I'm currently in search of the same thing you're doing, yet.. I'm not using a VG30, I'm using a VG33. So... I've still got to figure everything out, since I'm also not using a T3/T4, but a T04E. I'm sure there will be more knowledgable people to give you better suggestions than I can.
http://www.redz31.com/
http://mywebpages.comcast.net/engloi.../workpics.html
JD
voiceOFgod
Dec 22, 2006 01:14 PM
dmitry
Sep 15, 2005 01:17 PM
dashboardjebus
Sep 1, 2003 04:20 PM
300zxtwintrbo91
Sep 5, 2002 01:36 PM
