VG33E supercharger on VG30
Old Apr 2, 2014 | 12:22 PM
todd5854's Avatar
My question is, will the VG33 lower intake manifold pictured below, fit on my VG30E, to allow me to bolt the VG33E collector and VG33E supercharger on my VG30?
Please forgive me if this is a repeat, but I have found 0 information on this, at all.
I am debating supercharging my n/a VG30E VS just buying the turbo engine down the road from me.
Old Apr 2, 2014 | 04:53 PM
PredatorZ's Avatar
FSM's
You might try comparing the FSM's and see if you can see any bolt pattern differences. Most likely unless it was a stock setup. some fabrication is going to be required, if you have a skill set like Nismopick or TheRamz (just to name a few)then you can make all the parts you don't have (color me jealous, because these guys are really good at fab). Hopefully there might be someone in the forums with both motors sitting in they're garage.
Old Oct 31, 2014 | 06:29 PM
whiteout's Avatar
The manifold fits, direct bolt on. BUT the vg33e lower intake is missing two sensors. ( Im doing a vg33et build for my z31). You can use the vg30 lower intake on a vg33 block, or the vg33 lower intake on the vg30 block, how ever to do so you might have to look into adding said two sensors. Easiest solution is to use the vg30 lower intake and use the vg33er assoeries. You might have a slight problem with the radiator feed, just check that for clearances against your vg30 timing belt cover
chickenjoe
Sep 24, 2009 08:27 AM
pete8717
Sep 3, 2008 09:28 PM
ryanec
Nov 2, 2005 10:05 PM
n_2_fairladyz
Oct 14, 2003 10:58 AM
benz333
Jul 24, 2003 09:56 PM
