VG30 starting problem??
Hi all,
I have a friend here in Australia who has a 300ZX '84 model with the VG30 motor in it. He has a problem that is driving him crazy. . . he has been to the dealer and various other places but no-one seems to be able to fix it. the problem is: when the outside temperature is cool. ..like first thing in the morning . .. the car starts fine. When the outside air temp is warm or hot. . the car is very difficult to start. .. .Any ideas??? Thanks - Simon |
easy fix i had the same problem
fuel injector is in choke mode:::
when the outside temperature is cool. ..like first thing in the morning . .. the car starts fine. (car motor temperature sensor tells the car is in choke mode: so it starts When the outside air temp is warm or hot. . (the car is still in choke mode and tells the fuel injektor to run TO RICH ) (sleightly higher rpm`s) chokes it to death the car is very difficult to start. .. ??or will not start at all easy temorary fix un plug motor temp sensor (never choke) on the passenger side on the front of your car about by your radiator cap on top of your block are two plugs the one (two wire plug ) that set of wires goes straight down behind the timing belt cover thats the one just un plug that connector and try to start if motor is warm let me know if it woked i can get you details how to replace it if you want |
This orig post is almost 6 years old. Please look at the date before posting. :D
