tail lights won't go on ... replaced bulbs & fuses
Old Nov 29, 2006 | 05:38 PM
Turbo86's Avatar
tail lights won't go on ... replaced bulbs, checked fuse (good) replaced anyway ... turn signals work, brake lights work, hazards work ... but tail lights (running lights) and the 300zx turbo light if there is one doesn't work ... I was looking at the service manual and it shows that for the 1986 gll model there is a special tail light sensor could that be it? or could it be one of the fusable links?
Old Nov 29, 2006 | 07:05 PM
inqui-Z-tor's Avatar
You replaced w/1157 (2-prong) bulbs?
If you're using the right bulbs .. you might want to check for corrosion in the sockets.
Or lose wire .. either at the socket or the taillight sensor.
Pic below shows the different taillight sensor(s)
And .. 300ZX turbo reflector ... doesn't light up.
Old Nov 29, 2006 | 07:55 PM
johnZboy's Avatar
Distinquished Guest
Have you used a 12v test light to probe and determine if you have fire in your wires? Get one from Harbor Freight, or any el-cheap-o tool retailer, for less than $5. Owning and using one is a must for tracking down the electrical gremlins.
Old Nov 30, 2006 | 08:29 AM
Turbo86's Avatar
I used 1157 bulbs ... I have never seen the "300zx turbo" panel light up ... i see there is a some wires and a rubber gromet that goes into it thats diff. then the other turn bulb connectors ... I have a volt meter with probes ... what's the best way or where do i test? with or without car/battery on or connected? .... i have the purple guy in the picture i see it in the hatch area ... do i just replace it or test for contunity?
Old Nov 30, 2006 | 10:23 AM
get copy of 86 fsm .. it should have a write up on testing the taillightsensor
Old Nov 30, 2006 | 12:48 PM
Turbo86's Avatar
got one ... i didn't see it in there ... I'll look again
Old Nov 30, 2006 | 06:06 PM
Grimmace's Avatar
whats the 86 fsm????
Sounds like I could use one.....
Old Nov 30, 2006 | 06:27 PM
johnZboy's Avatar
Distinquished Guest
Factory Service Manual
You were kidding, right?
A Haynes manual is a little less expensive, and easier to obtain. It works quite well for the home (and many shop) mechanics.
Old Nov 30, 2006 | 06:35 PM
Turbo86's Avatar
i got the haynes manual at half price books for $8 and I downloaded the 86 and 84 FSM in pdf form from car fiche.com site for free and i print out the pages i need for whatever job i'm doing to take to my car when I'm working on it. ... beats paying $18 bucks for haynes at autobone and $50-$70 or so for FSM in print
Old Nov 30, 2006 | 08:14 PM
In the 84FSM .. the taillight sensor is in EL .. just before the bulb specifications. Maybe the 86FSM is organized in similar fashion?
Old Nov 30, 2006 | 09:13 PM
rogerz's Avatar
Grumpy & Helpful
the turbo z thingy just holds the license plate lights which is why it has wires going to it.
Old Dec 1, 2006 | 06:57 AM
Turbo86's Avatar
so it never lights up?? ... that would be cool if it did maybe i'll fabricate the back of it and add a light that whould be cool
Old Dec 1, 2006 | 07:23 AM
Someone mod'd the reflector to just allow the 300ZX TURBO to light up. They had to do some minor modification to the backside of the reflector to get that to work.
I"ll have to see if I can find the url where the information is ..
http://homepages.picknowl.com.au/djkemp/mods22.htm
Something I haven't "yet" tried out myself ..
Old Dec 15, 2006 | 04:28 PM
z-hag's Avatar
Queen of Yachts
i like that a lot--looks cool. i always wondered why that did not do that--after all----lites are better than reflectors.
aujbman
Sep 18, 2013 04:18 PM
Murph Z32
25
Oct 7, 2012 08:07 PM
kr11zzz31
Sep 8, 2011 07:39 PM
Turbo86
Jan 15, 2007 03:45 PM
forcedfedz32
Mar 1, 2006 08:08 AM
