Starts then stalls
my Z was running great the one day I parked for an hour, now it won’t stay running. It turns over with no problem but after 5-20seconds it stalls, Giving it gas makes it stall right away. If i prime the fuel pump and pump the gas it runs a bit longer. I’ve changed my fuel relays, and fuel filter. Next I was going to check my fuel pressure and MAF.. any other ideas? also changed the TPS because the housing was broken. |
I would start with fuel pressure first. Pull the vacuum line off the fpr and make sure there is no gas coming out of the vacuum port on the fpr. |
Were you the one on Facebook who brother in law stole your gas? |
