ZDriver.com
-   300ZX (Z31) Performance / Technical (https://www.zdriver.com/forums/300zx-z31-performance-technical-227/)
-   -   So afraid!! (https://www.zdriver.com/forums/300zx-z31-performance-technical-227/so-afraid-22125/)
cliftcrawford Mar 11, 2007 07:34 PM
So afraid!!
I was cruising in my 86na a couple of days ago. I noticed a slight stall, then another then my temp gauge goes to almost 270. I pulled over and the car had overheated. put water and antifreeze in but the car wouldnt start. I got it home, crawled under it. When the motor turns over, antifreeze blows out the exhaust manifold where the exhaust pipe connects. Im afraid that ive cracked a head, cylinder, or, best case, a blown head gasket. Has anyone got any ideas before i tear the heads off?
z-hag Mar 11, 2007 07:47 PM
i have a 1986 na engine in better shape than yours but needs rebuild--never been overheated and not seized. needs main bearing, oil pump, rings and valve job--hay, its gonna be apart--might as well check out the rest--------good strong engine before suicide by oil pump.......
NismoPick Mar 11, 2007 07:49 PM
Pull your spark plugs & look at the tips. If it's blowing coolant out the exhaust... 99% sure you warped the head & melted the headgasket.
z-hag Mar 11, 2007 07:53 PM
i yam in coronado--car soon to be more inland and dismemberable---come on down---ps-----bring a truk.........
cliftcrawford Mar 11, 2007 08:07 PM
I just did a complete rebuild 3k miles ago. looks like ill be in the market for some heads.
z-hag Mar 11, 2007 08:16 PM
well, homes, come on down..........what else do you wish from the royalpain piglet??????......ps--where are you......
cliftcrawford Mar 11, 2007 08:21 PM
central louisiana
snwbrderphat540 Mar 11, 2007 08:47 PM
hehe... a lil bit of a driver to cali then... might not be "comin on down"
