Please Help
Old 10-03-2008, 09:32 AM
84z31nonturbo's Avatar
Please Help
Ok, I have a problem. When I started my 84 na this morning it kinda stumbled when I first started it, it didn't want to idle. After feathering the throttle for a minute or two it idled fine. So I let it warm up for about ten - fifteen minutes and when I go to take off it dies. Every time I hit the throttle even a little bit it dies. I cant even get the car to move. I have never had this problem before. Last night when I drove it, it ran fine. It has all new vaccum lines, I put a new fuel filter on and it didn't help. I tested the fuel pressure at idle and its fine, the fuel pump sounds like its working fine, so I'm stumped. Any kind of help would be greatly appreciated.
84z31nonturbo is offline
Old 10-03-2008, 10:58 AM
East Coast Style
EZDUZIT's Avatar
Check your connection on the MAS Air Flow meter. Make sure it is plugged in good and making good connection.
EZDUZIT is offline
Old 10-03-2008, 03:41 PM
maf is plugged in and connection was cleaned about a month ago. The plug has not been disconnected since.
Old 10-03-2008, 04:15 PM
check the TPS amd run the codes, if your really up for it you could also convert to the 87+ EFI system and have a bit less trouble.
hoov100 is offline
Old 10-03-2008, 05:15 PM
Distinquished Guest
johnZboy's Avatar
Question Has Anyone Mentioned The Codes???
I believe hoov100 said "run the codes." Good advice because otherwise you are just guessing...
johnZboy is offline
Old 10-03-2008, 06:27 PM
Yeah, I'll try that tommorrow and let you know how it turns out. Thanks so much for everyone's help.
Old 10-04-2008, 06:46 PM
So I ran the codes and it came up with 12, which is maf sensor or the wiring for it. So I cleaned the plug again and it didnt help. Luckily I just happened to have a maf sensor from an 85 turbo z31, so I tried it and now it runs fine. The maf sensor from the turbo car should be fine on the na car... right? Also, the ecu came up with a code number 23, but the paper I have doesnt show a code 23, does anyone know what this could be?
Old 10-04-2008, 07:35 PM
Distinquished Guest
johnZboy's Avatar
Cool Here ya' go....
Code 23 = Throttle Position Sensor (TPS)...
johnZboy is offline
Old 10-04-2008, 10:30 PM
NisTuner
duowing's Avatar
As far as I'm aware the MAF is the same from all year Z31s Turbo or non-turbo.
duowing is offline
Old 10-05-2008, 02:49 PM
The page I have says code 43 is the tps. http://z31.com/oboard/archives/view.pl?151 And thanks again for everyone's help. Nevermind, on the page I have its saying 23 is the idle switch, I already knew that was going bad.
Old 10-05-2008, 03:12 PM
Pr0n Addict
KasbeKZ's Avatar
wow. i didn't believe that the turbo and N/A MAF would be the same so i looked it up and sure enough, Z31 MAF is for all models. i don't see how that can work. i guess stock boost is pretty low for them though.
KasbeKZ is offline
Old 10-05-2008, 03:18 PM
just for future reference, the 87+ ECU's have different codes then the earlier ones, i tried using a FSM from a 85t on my 88t and the codes where completely off.
hoov100 is offline
Yeah, lol. Im glad they are the same I dont have the money to go buy a new one. I just happened to have this one here from my 85 turbo parts car.
Old 10-05-2008, 03:19 PM
What is FSM?
Old 10-05-2008, 03:22 PM
FSM=factory service manual the service manual given to dealers when a car comes out.
hoov100 is offline
Old 10-05-2008, 03:26 PM
Ah, I see.
