Motor is Running off of Starter fluid but not Gas
Old Nov 20, 2017 | 12:15 PM
savio87's Avatar
I have a 1987 300zx nonturbo and im having problems trying to get it to run. The car will run off of starter fluid and I have good fuel pressure coming off the filter but i guess fuel is not making it to the cylinder somehow. I didn't know if it could be a bad fuel pressure regulator or what. Thank you in advance for any advice.
Old Nov 21, 2017 | 08:04 AM
Welcome to ZDriver!
If it starts with starting fluid, you have spark, no fuel delivery. If you have truly verified that you do have a constant proper fuel pressure (~30psi, doesn't drop), then your fuel pump is working and the fuel injectors aren't spraying. There can only be a few reasons why:
-Toasted fusible links
-Disconnected wires to fuel injectors
-Toasted ecu
Check them.
Old Nov 21, 2017 | 03:15 PM
savio87's Avatar
I'll give it a shot. Thanks!
Virtuoso
Jul 27, 2013 12:23 AM
BlakesZX
Apr 3, 2012 10:35 AM
KasbeKZ
Other Cars
Nov 19, 2010 06:16 AM
thxone
Nov 19, 2006 09:33 AM
AlongCamePeter
Sep 12, 2004 06:20 PM
