MAF wiring for JWT 450 hp
My '86 turbo MAF harness has 2 black wires with red markings (not stripes)...are these both grounds?
If so, do I then connect B and C grounds (from the ford MAF) together to just one of the OEM grounds.... or do I connect them separately (one to each OEM ground).
The large black w/ orange ring (Wire in position C) is a ground.
The small black w/ orange ring (Wire in position D) goes to the ecu (ecu harness PIN# 26).
Check this out: ( http://jimwolftechnology.com/wolfpdf...%20UPGRADE.PDF )
Even though it's instructs for the 280ZXT swap, it has good info on the Cobra MAF.
Ya I tried to followed JWT instructions for the wiring...in my harness there is:
1. a black wire with white stripe. I connected to A... No problems.
2. black wire in a grey sleeve... I thought this is what JWT meant
as being "shielded".....? is this right? I connected it to D
AND 2 black wires with the red marking which are the same size...where do they connect to?
thanks
thanks
thanks
thanks
gergstuff
11-22-2014 08:57 AM
Nick Napala
FS: 300ZX (90-96)
02-07-2014 01:55 AM
