I want to cry.....:(
Old Sep 7, 2007 | 10:36 PM
titan74's Avatar
Hello to everyone i'm a z fan i have had a 79, 82 280zx and a 85 300zx and now i have a 1988 non turbo 2+2. When i tested it it ran great i had it towed to my house and for some reason it won't start the engine turns but wont kick over. Also there's no spark from the plugs (i checked them out and they looked fine) the codes were 11(crank angle sensor) and 22(fuel pump circuit). I'm ok at fixing the problem but i never experienced this with the 85 z i had. If anyone can point me in the right direction i'd greatly appreciate it thanks.
Old Sep 8, 2007 | 08:14 AM
Goofyz's Avatar
when you towed
did you tow it backwards? or on a flatbed? cause if you towed it with the front wheels up and the back wheels down, you might have screwed up your timing belt, jumped a cog or two.
Old Sep 8, 2007 | 10:35 AM
titan74's Avatar
It was on a flatbed.
Old Sep 15, 2007 | 08:15 PM
asswho's Avatar
wont run
try resetting the fuel pump relay (on a 86 its right behind the glove box). just hit the little rubber button on the left side. hope this helps.
