how to remove AFM
Old May 19, 2011 | 03:32 PM
supalax15's Avatar
how to remove AFM
Just want to see proper steps to remove the AFM? Car is rough out of 1st gear and trying to see if replacing AFM helps out? Plugs looked good. Thanks guys. Hope to do this saturday to see if it helps.
Old May 19, 2011 | 03:38 PM
two hose clamps on either side, the plug and four 10mm bolts on the bottom under the bracket.
Old May 19, 2011 | 04:37 PM
omniserv's Avatar
for us it was easier to remove the bracket and the AFM together.
Old May 19, 2011 | 04:58 PM
supalax15's Avatar
how do you get to the bolts under the AFM? i looked very quickly due to weather and knew there was not much room to work with.
Old May 19, 2011 | 06:12 PM
omniserv's Avatar
you should be able to just remove the bracket, there's 3 10mm bolts in it. either way it's not fun.
Old May 21, 2011 | 05:22 AM
supalax15's Avatar
i have removed two screws and do not know how to get to the last screw? Knew this would be a little bit of a pita but didnt think it would be so difficult. any help with getting this thing changed? going out for round two right now to try. any help would be appreciated to getting this bracket off. the two screws i have off are the ones on the right of the afm.
Old May 22, 2011 | 03:12 PM
supalax15's Avatar
thanks for the help. it was a major pita. had to take screws off bottom of afm and take it off that way. took some time however its done and car drives better.
LemonHead
Jan 10, 2012 07:46 PM
8ty7z
Jul 27, 2010 12:14 AM
duowing
Dec 27, 2007 12:25 PM
RodMoyes
Jun 26, 2006 01:33 AM
Skully
Oct 10, 2002 07:52 AM
