Hole In Firewall
Does anyone know the most convenient spot in which to run a power cable through the firewall. Its always a hassle in a new car locating an spot that can easily fit a larger power cable for an amp. Thanks Guys
just take an already existing gromet and make it fit, it SHOULD work, if theres no space then just make a hole and gromet setup where you feel is most appropriate and will work, or ghetto it and run it through the fender. your call
Originally Posted by ZThirtyOne
(Post 251656)
Good luck! |
I ran mine through the grommet on the passenger side. I think it was the one behind the air system. I remember I had to remove a bracket on that to get to it.
