Help me
Old Nov 21, 2005 | 05:59 PM
drummer69's Avatar
Help me
My baby, an 85 300zx NA, I turn to start the car, she has a slow crank, not too slow but slow sounding like it was the battery, I had just checked the battery all is good, I even put an alternator in 2 months ago and that reads good. could that be the starter ? the selenoid ? Is the starter very hard to change in that type of car, I can't find it, on my 82 280zx it's like right there .
Old Nov 21, 2005 | 06:01 PM
AZ-ZBum's Avatar
Could be the connections, could be the starter. Doubtful it's the solenoid, but the solenoid is built into the starter itself, kinda.
Old Nov 21, 2005 | 07:21 PM
drummer69's Avatar
is that hard to change the starter
Old Nov 21, 2005 | 08:08 PM
RodMoyes's Avatar
Doesn't post much...
Check the battery cables all the way down. Sometimes they corrode internally. If there are brittle spots, you know you have a cable problem. Like AZ_ZBum wrote though... Could be the connectors themselves. Finally, small chance but... There is a starter wire under the car that can get loose or dirty and cause a weak connection. I doubt that's it though.
Rod.
Old Nov 22, 2005 | 11:53 AM
motoxracing909's Avatar
On my 1985 300zx turbo the starter was fairly easy to remove if your under the car it is on the right side a couple bolts and wire removal and it's out.
Old Nov 22, 2005 | 11:54 AM
If you get that out you can take it to O'reily and they have a machine to test them on for FREE!
