Heat is always coming out.... help
Old Oct 2, 2006 | 04:03 PM
Abneya's Avatar
Ok... so my a/c can still be turned on and all... even if its charged... hot air (not luke warm... HOT) ALWAYS comes out of my vents. I closed off this valve near the firewall of the car towards the top of the engine bay and that helped... but eventually my zip ties fall off and I'm back to hot air... any ideas why this might be happening?
Old Oct 2, 2006 | 04:19 PM
Z Car Barbie's Avatar
User Friendly
If you have plenty of freon, then check your vacuum lines for splits or deterioration. It appears that you have a vacuum leak somewhere.
Old Oct 2, 2006 | 05:09 PM
Abneya's Avatar
diagrams???
Anyone have a diagram of the vacume lines and where they run?
Old Oct 2, 2006 | 08:21 PM
Abneya's Avatar
i found them.... good ole' haynes manual
Old Oct 2, 2006 | 10:44 PM
z-hag's Avatar
Queen of Yachts
my mechanic told me there are "gates" that do not always change--hot gets hotter with accel--all 3 of my z31s had that problem--now only 2 still do. there is a way to turn manually the heater off or to a lower setting so it won't hahahah come on again--only stays for a short time. take off the ttops. open the windows. if slicktop--fix it.
ol55
Dec 17, 2013 02:36 PM
fozs00
Nov 28, 2006 01:07 PM
Dorifto
Oct 14, 2005 02:48 PM
nuzxowner
Feb 13, 2005 06:38 AM
GenHawk
Jun 5, 2003 12:06 PM
