Fuel pump
I was told my new fuel pump.a Airtex is not working right
I was told the correct way to install the pump.and pull out the gas tank then put in the new pump I don't think this was done the first time I was.told to do the job right 3.5 hours at 100.a hour so this time I'm asking You guys for help and insights th a la Anthony |
Yes pulling the tank is the way it’s normally done. If this wasn’t done the first time did they cut an access hole to replace it? Otherwise it wasn’t done. |
Fuel pump
Hay thank u for the reply
at least my airtex fuel pump is under warranty The only fuel pumps I could find was the airtex or the spectra are there other pumps.? available Thanks spike114 |
