Fuel pump
Old 10-12-2018, 12:16 PM
spike114's Avatar
Fuel pump
I was told my new fuel pump.a Airtex is not working right
I was told the correct way to install the pump.and pull out the gas tank then put in the new pump
I don't think this was done the first time
I was.told to do the job right 3.5 hours at 100.a hour so this time I'm asking You guys for help and insights th a la Anthony
spike114 is offline
Old 10-15-2018, 08:10 PM
JSM
JSM's Avatar
Yes pulling the tank is the way it’s normally done. If this wasn’t done the first time did they cut an access hole to replace it? Otherwise it wasn’t done.
JSM is offline
Old 10-16-2018, 05:38 AM
spike114's Avatar
Fuel pump
Hay thank u for the reply
at least my airtex fuel pump is under warranty
The only fuel pumps I could find was the airtex or the spectra
are there other pumps.?
available Thanks spike114
spike114 is offline
vg30_s12
02-26-2013 09:46 PM
Turbo86
06-08-2007 01:47 AM
Mike Phillips
10-20-2006 02:28 PM
theZking
03-26-2003 07:49 PM
Craig_Paterson
11-16-2002 06:22 PM
Quick Reply: Fuel pump
