**** Up
Old May 18, 2005 | 02:29 AM
Velox ZX's Avatar
From: I'm located in the more southern local... Jackson, MS.
**** Up
I think I ****ed up... I was all pissed off that my car wouldn't start... I've decided it's my fuel, apparently I believe there's debris in my tank..... well my dumbass decided to pull off my air filter and use starter fluid to try and crank her... well she back fired... down the intake tube, I wasn't aware this was a problem untill just a few minutes ago when I was reading about FPR's with broken diaphragms exherting too much fuel into the engine..... and now I can't get her to crank at all, not sure if it's because of the debris, or the MAF sensor that I MIGHT HAVE ****ED UP.... advice, help, insight?????? ....anyone...?
JD
Old May 18, 2005 | 08:41 PM
Jerkif's Avatar
you ****ed up
Old May 18, 2005 | 09:08 PM
Spudz's Avatar
First of all you might try using appropriate language !!!!!!!!!!!
This will be your only warning .
Old May 19, 2005 | 05:14 AM
Jerkif's Avatar
sorry it wont happen again
Old May 21, 2005 | 01:53 AM
86zxt(954)'s Avatar
hope is the maf sensor..... for your sake kid..... i would relieve the fuel press.... so at least accelerate the process to get rid of too much fuel.... then get a maf sensor $200 and try her.... if this is the case she wont cranck rite away... "try her"....
B1nAryVilE
Jan 23, 2005 09:42 PM
