Finally
Old Feb 6, 2006 | 01:15 PM
91Zman's Avatar
Opinionated
Finally
So id like to say my problem is solved. My jerky Acceleration. The Throttle positioning switch is bad, i just disconected it. What role does that Play on a n/a 5 speed? I heard it was just for Auto trannys?
Old Feb 6, 2006 | 02:08 PM
TPS (THROTTLE POSITION SENSOR) sends a signal to the ECU... doesn't matter what trans you have.
Old Feb 6, 2006 | 02:19 PM
91Zman's Avatar
Opinionated
Would it hurt to have it disconnected?
Old Feb 6, 2006 | 03:34 PM
AZ-ZBum's Avatar
Why not just adjust it properly?
http://www.carfiche.com
BTW: It's a SWITCH on the 5 speeds.
Old Feb 6, 2006 | 04:01 PM
91Zman's Avatar
Opinionated
i just had to disconnect this wire from it is all. It was this little black box on the side of the Throttle body held on by 2 screws. It seems that that male connectors are corroding
Old Feb 6, 2006 | 04:58 PM
Well I'll be damned!
Old Feb 7, 2006 | 10:40 AM
WolfMan's Avatar
a switch.. plz explain, mine is the black box also. I am having serious issues with it, horrible idle, but runs great, when I give it gas and move.
Old Feb 7, 2006 | 12:15 PM
91Zman's Avatar
Opinionated
My idle is fine, it just accelerates really poor and its jerky/sputtering, but ive noticed that most of the time its just in the morning.
Old Feb 7, 2006 | 06:38 PM
AZ-ZBum's Avatar
if you read the instructions for how to adjust it in the fsm, it might give you a clue.
Old Feb 8, 2006 | 11:06 AM
WolfMan's Avatar
fsm? I adjusted the tp sensor, was pretty easy. it was just finding the ohm meter.
Old Feb 8, 2006 | 12:23 PM
entropy31's Avatar
The Cake Is A Lie!
fsm=factory service manual. i highly reccommend you get one.
Old Feb 8, 2006 | 09:26 PM
WolfMan's Avatar
I have the hanes, is that good enough? The car runs really rough, until I pull the wire off of the TP switch. I tried adjusting it as per Hanes. But with no success, I switch the sensor itself, still got issues. How would I go about cleaning the throttle body? Becasue I kno that once you disconect the sensor, the ecu runs a program for fuel vs what the engine is telling it.
I am sorry for biggy backing, but this might help you too if it gets answered.
Nforce1
Jun 24, 2005 12:19 PM
ensmuns
May 3, 2005 05:38 PM
My Fairlady Z
Sep 27, 2004 01:14 PM
TheZerminator93
Aug 31, 2004 02:40 AM
ZenArcher
May 17, 2004 10:00 PM
