feulpump issues
hey guys i pulled the pump outta he 84z i bought its the 50th aniversery n/a
anyways when i hooked the pump up to a battery is worked great so i put it back in and ran if for a few days im thinking its the relay or a ground the car has not been started in over a year so.. whare os the relay and how do i check it because im pretty shure its not the pump i downloaded the service manuel no luck on findin the relay in thare |
then you downloaded the wrong manual. clearly shown if you read it.
hmmm
thats why the compressed folder sais 1984 nissan 300zx right 0.o
50th Anniversary Editions weren't NA.
http://www.az-zbum.com/information.50th.ae.shtml Fuel pump relay is in the right side b-pillar. You might be able to get to it by removing the vent in the door jamb. |
thank you Az-zbum i found it replaced it wierd same thing goin on i pulled the pump hooked it to abattery it spun up like a top i stick it back in it won't fire up thinkin a short mabe
Ecu.......
well az-bum looks like im droppin the tank took a ohm meter and the pump is bag grr oh well such is life
err bad i need a new keybored and typeing lessons :P
And English lessons. Your grammar is horrible. Try using punctuation.
Originally Posted by az-zbum
(Post 292802)
and english lessons. Your grammar is horrible. Try using punctuation.
heres your puctuation .!..
i still don't get why you have to be assholes to people that are just trying to get help but mabe this place is for snobby ****ers if that the case i really dont need to come here im shure thares other zcar sites on the web so if my grahmer bothers you thats your problem not mine
I owe you guys an apology.. sorry for flying off the handle at you guys just fustrated with my car is all.
Originally Posted by mook627
(Post 292827)
