engine swappin fun!
engine swappin fun!
ok heres the thing im am definetly going to be swapping a 90-96 tt into my 88 turbo
i was wondering was wonering what all has to be done to make the tt fit
and no im not concerned with money.
but i would like a small headcs up on whats got to be done.
im new to the forums !and im happy to be here!
any reply would be great!
How much can you afford.
The fact you just asked means you probably can not prefrom the swap.
It is possible BUT very very expensive. In fact the VG30ET will be a better motor in the end; plus with the 1000s you will spend for a VG30DETT swap you can make one hell of a powerful VG30ET that is an all around performer.
Go ahead and scra the idea. Your looking at custom engine and tranny mounts, custom driveshaft, custom shifter, a new cooling system (mostly custom), an intercooler, piping for the intake and intercooler, custom wiring harness, ecu, VG30DETT, custom vaccuum system, and many many other things.
yea i have kinda been thinking about
not swapping..,but it seems like a quick way to het hp!lol
does any know if there are any larger after market turbos made for an 88?9(87-89)
i much appreiciate the info
Yes can you search? JWT sells bigger turbochargers. http://www.jimwolftechnology.com/customer_results.asp
www.redz31.com (has a section about it)
www.Z31.com
http://z31.com/tfaq/
Stock you have a T25 which isn't going to get you anywhere. Your best bet will be a good T3/T4.
www.Z31.com
I'll have to side with James, I'll put my 84ZXT up against any TT dollar for dollar. The fact is I can do more with less money than you can with the TT. Also a single turbo will out perform a TT set up. As a matter of fact my car with a stock T-3 turbo and a $40.00 boost controller out runs TT all day long. They better have some serious mods to run with mine now. There is also ways to to get more displacement with the VG30ET 3.4Liters MORE
Save yourself alot of time and $, 400 hp is very obtainable and after that in these cars is pointless. It would be all you can do to keep the rear planted and hooking up. Hell I have a hard time in Street War class keeping mine straight at the drag strip with a welded rear! On top of that I bet Im not putting out more than 250-260 hp to the rear wheels in my car.
Dude the simple fact is this. If you want to go with a TT it would be better to just go out and get one. But the money you spend just to buy one will be about more than half you could spend just to do simple mods to your z31. Two turbos doesnt necessarily mean that there better than one. A matter of fact having two turbos usually means more turbo lag. That is what you dont want. Having a single turbo with a blowoff valve, boost and hks exhaust would give you one bad machine. Add an intercooler and wastegate and i'll put money on your beast anyday. Im not trying to talk you out of doing the swap because you should do what you want because it is possible and original but its gonna cost you a few pretty pennies. if You any questions on the swap email me and I'll give you info on what you need to do. My uncle completed the swap about 3 months ago. It gonna cost alot.
look im not trying to have sum dumb *** argument with anyone i was only looking for a little info,
but i do plan on keeping the turbo and just modding it
and im grateful for all the advice youve givin me its really appreciated
but in my opinion i still still belive in the end you COULD achieve overall more power with a tt if certain precautions are taken i know using the vg30et is more bang for the buck but what im aiming for is a more
complete power gain.
No one is trying to argue with you bro. We are just saying that the vg30 will produce a lot of power for not a lot of money. But if money in not a problem then doing the swap would be a nice to see because there are not to many of them out there. Nobodies debating your gonna do what you wanna do. Good luck.
Originally Posted by Johnny Z
anyone seen the vg33 turbo that makes close to 600 hp that guy says its better than his vg30tt
Guest
Posts: n/a
I have a VG30ET in my 510 running at 17psi with tubular headers and a big T3-4
A friend is building up and is almost done with a VG33ET forged VG30DE rods and crank plus forged pistons o-ringed block and copper head gasket. He just needs to assemble. The turbo is a big T60 good for 650hp.
All this in a 510.
These engines are very strong and don't need any mods other then ECU and injectors to get to 400hp.
Ken in AZ from Hybrid Z has an NA VG Pathy intake and is at 450hp to the ground. On stock block and cast pistons.
Im running stock ECU and injectors and two piggyback Subaru injectors running off a Megasquirt thats triggered by a Hobbs switch.
All this in a 510.
300zgearhead
May 6, 2010 11:45 AM
smokingzcar
Dec 5, 2002 07:57 AM
