Electrical problem! (Please Help)
Old Oct 11, 2006 | 02:12 PM
did you say you changed the battery? it should run no prob either way since its a manual, self sustained system and crap...but on my old auto camry i had the battery was soo far gone that even with a good alternator it would die...but you can start your car off your battery currently i assume huh? so this might not be the prob.....
Old Oct 11, 2006 | 02:53 PM
rogerz's Avatar
Grumpy & Helpful
check your ground cable all the way to the starter. I believe there was a ground wire to the firewall originally (so I was told when someone told me why there was a hole in the firewall there). I ran two pieces of #10 cable to screws at either side of the engine compartment on the advice of a friend who is very z knowledgeable. Bad grounds can cause lots of weird electrical problems and are sometimes hard to locate. I also have a 85 but a turbo. It appears you did change the battery so that shouldn't be an issue. You should also put a voltmeter across the battery and see what the voltage is doing when revving. Internally regulated voltage.
zfanman
Oct 20, 2008 04:28 AM
BackHouseZ
Apr 7, 2008 11:36 PM
dragon
Feb 11, 2008 12:41 PM
NwZXlover
Jun 9, 2003 08:29 PM
