Ecu
Old Feb 28, 2005 | 06:29 PM
Johnny Z's Avatar
Ecu
I just found out that the ECU im running on my turbo is an NA wut type of problems will this present
Old Feb 28, 2005 | 07:33 PM
00Evan's Avatar
Banned
You'll blow the motor the **** up and it wont run right at all.
Old Mar 1, 2005 | 06:57 PM
91zxtt's Avatar
How did you wind up with the wrong ECU?
Old Mar 1, 2005 | 08:04 PM
Johnny Z's Avatar
Ecu
the guy that sold it to me told me its an NA ecu im running stock boost the car runs fine except for some idle issuses how can i know for sure its an NA ecu
Old Mar 1, 2005 | 08:53 PM
ZenArcher's Avatar
Apparently you aren't going to "blow the motor the fvck up" that easily. Remove the kick panel and check the numbers against this list to find out what ECU you have in there.
Old Mar 2, 2005 | 06:52 PM
Johnny Z's Avatar
Ecu
well i got an auto NA ecu on my 5 spd TURBO wut does the #25 represent on the ECU cause ive got an ECU with 25 and that on works the one with 24 on it makes the car sputter. Where can i get the right ECU much thanks to all for your help
Old Mar 2, 2005 | 09:08 PM
Redbeauty84ZX's Avatar
Post on www.z31.com alot more people there are likely to have one.
Old Mar 4, 2005 | 03:55 PM
Johnny Z's Avatar
Ecu
where else can i get one
Old Mar 4, 2005 | 07:44 PM
mdharris11's Avatar
Ecu
You can, of course, buy a remanufactured one from one of the chain stores (e.g. Adavance Auto). Just tell them what you need -- year and turbo engine (don't tell them you have the wrong ECU for the core naturally). I think they run a little over $200.
Old Mar 4, 2005 | 11:35 PM
I have an extra ECU I pulled from a junk yard a while back. Anyone know how to tell if it was a 5 speed/auto or turbo/na?
Old Mar 5, 2005 | 08:04 AM
ZenArcher's Avatar
Well...you could check it against that list I linked to...
Old Mar 5, 2005 | 05:29 PM
Johnny Z's Avatar
Ecu
give me the number on it and how much you want Thanx
Old Mar 5, 2005 | 08:15 PM
ok the only numbers I see on the ECU are All -B45 GO8 and 0106
