Digital speedo reads 0 most of the time
Old Apr 8, 2013 | 09:25 PM
Z92AL's Avatar
What all could cause my digital speedo to read 0 most of the time?. Every once in a while it will kick on, and read for a couple miles then go back to 0.
Old Apr 8, 2013 | 09:33 PM
Bent / kinked / dry speedo cable... that's the first thing to check.
Old Apr 8, 2013 | 09:51 PM
PredatorZ's Avatar
Z31 digital speedo cable
Your cable could be broken, it will occasionally catch, the 2 broken ends making contact and getting some rotations in. If it's broken, you can replace the cable inside your housing, as long as the housing is kink free and not binding. Give Steve a call, he has a cable on his site (page 77), $30 to your door. 300zx Parts For You webpage
You can download a factory service manual, it will walk you through the replacement, I'm sure there's probably a few write ups online.
XenonZ31 Reference
Does your odometer work correctly ? If so your speedo cable o-ring could be leaking trans fluid into the sensor, giving you some pretty erratic readings. Found this post on Nico, check it out Speedometer issues 86 300zx gauge dash : Classic Z Technical
Old Apr 11, 2013 | 10:35 PM
Z92AL's Avatar
Sorry ive been busy and forgot to reply.
No my odometer doesn't work at all, and the car is an 87 turbo did they use a speedo cable
that year or does it have some kinda sensor?
Old Apr 11, 2013 | 10:39 PM
PredatorZ's Avatar
Cable
Steve has a cable and housings, if your housing is good you can order one from him, he salvages mostly Z31's, there's a link in my post above for the part and that it takes a cable
bkubisht
FS: 300ZX (84-89)
Apr 13, 2021 06:59 AM
wgc_3
Oct 27, 2006 06:31 AM
3XAZOWNER
May 20, 2006 07:16 AM
NwZXlover
May 30, 2003 09:25 AM
NwZXlover
May 27, 2003 06:23 AM
