Difference in distributors?
Old Aug 19, 2007 | 03:16 PM
AgentZ's Avatar
Thanks for reading.
Is there any difference between a turbo dizzy and an NA Dizzy?
I had what seemed to be a bad pickup in mine so I had to swap it. Only one I could get from the wreckers was a turbo dizzy. I now have a car that runs!
Only problem is now once the egine warms up it stumbles from about 2000rpm to about 2800 rpm.
Any ideas
Old Aug 19, 2007 | 03:44 PM
No difference... did you reset the timing?
Old Aug 19, 2007 | 03:49 PM
AgentZ's Avatar
well.....umm yeah working on that right now!! seems that on another job, when I had the damper off I put the pulleys back on in the wrong postion. so I have to take off the pulley, set the engine to TDC and put the pulleys back on then set the timing. I really hope this fixes the stumble!
Thank for the quick reply!
Old Aug 19, 2007 | 08:50 PM
AgentZ's Avatar
Ok, have fixed up the pulleys now and it is all good in timing. Spot on now!
Still stumbles once it heats up. Its always at the same rev range. I am starting to get really lost here
Old Aug 19, 2007 | 09:01 PM
Air Regulator, MAF, or CHTS... Check the wiring / connection on those sensors.
reddevilZ31
Jun 22, 2013 01:26 PM
3XAZOWNER
Jul 6, 2006 08:45 PM
jmmorriso
Jan 13, 2006 06:41 PM
BigLou's300zx
Dec 16, 2003 06:21 AM
Cardoo
Jul 8, 2002 02:45 PM
