cylinder temp sensor / coil
Old Feb 6, 2007 | 06:01 PM
cliftcrawford's Avatar
Will a defective cylinder head temp sensor prevent a car from starting? I have an 86 300 na and I can drive it to work in the morning but that afternoon it wont start. the next morning it will. Ive ran the diags and get a 21 code. My coil was loose and i tightened it - it may have not been grounding? Now, when im driving it cuts out a couple of times but doenst die and seems to be starting fine. I thought it might be a cyl sensor but may be a defective coil?
Old Feb 6, 2007 | 08:34 PM
When a car doesn't start it's missing:
#1... proper fuel mix
and/or
#2... spark
and/or
#3... oxygen (air)
Are you getting spark at the plugs? Are you getting fuel? I'm not sure why you'd be checking the CHTS (cyl temp sensor) if the ecu is showing code 21.
Old Feb 7, 2007 | 04:02 PM
I thought of it may be a sensor when the car wouldnt start in the evening and I didnt have the ecu out to diagnose. I did check the coil and didnt see any spark. when i did get the car home the next day(it started and ran well) and ran the diags, i got a code 21 but the car did start and i could smell gas.
Old Feb 7, 2007 | 05:37 PM
entropy31's Avatar
The Cake Is A Lie!
the car will start and run with a bad CHTS. a bad CHTS will make the car run rough when cold, but it will run. you have other problems.
turbotim
Jun 5, 2013 09:22 AM
steve
Nov 8, 2011 03:27 PM
TheGrimaceTab
Sep 21, 2009 12:54 PM
one_fast_300zx
Oct 10, 2007 12:43 PM
