Crank Angle Sensor
Ok I've narrowed down my problem and what I'd like to know now is, how can I test my crank angle sensor. I'd prefer if I could do it, but if I have to take it somewhere, then where should i go?
Are N/A and Turbo crank sensors the same?
Yerp.
Just run CODS from your ECU!!
I tried that but it didn't light up, and it looks like i'm not getting power to my crank angle sensor.
Originally Posted by FlyAssMelonBall
(Post 315226)
I tried that but it didn't let up, and it looks like i'm not getting power to my crank angle sensor.
Is the ecu getting power? |
light up n yeah we tested it and cleaned the connectors.
You tested it? I thought you said it didn't light up?
Did you perform the ecu diagnostic test? Is the ecu getting power? aye aye aye... don't make this complicated... |
Sorry, the ecu isn't lighting up, but its getting power. I'm also not getting a lot of power to the crank angle sensor, the tester read .01 to .02.
| All times are GMT -7. The time now is 08:56 PM. |
