clutch problems
Old Apr 1, 2012 | 11:37 PM
87_silverz31's Avatar
clutch problems
Hi im new here and looking for some help.I have an 87 z31 turbo 5spd.Last summer my slave went bad so i replaced it and everything was fine.Now i took it out of storage and my master was bad so i replaced that.And did the damper removal mod.And ever since then its ben nothing but probs.When i try and bleed the clutch it just shoots out foamy fluid.Iv ran a quart threw the hole system.my clutch pedal just goes to the floor with no back pressure.So i tried a different way i seen to bleed it by squeezing the slave and pushing the air out the master but all it did was push all my fluid to the master with a bunch of air almost like the slave is sucking air in.So lookin to see what i should do.And everything is dry and tight but the slave is damp around the boot.So could it be the slave sucking air back into the system?
Old Apr 4, 2012 | 07:02 PM
AZ-ZBum's Avatar
You probably got a bad master cylinder. Or your slave took a dump at the same time. That's why you should always replace the parts as a set.
Old Apr 7, 2012 | 10:56 AM
Yep it was the slave i got it fixxed a couple days ago.funny thing is though is it didnt leek.
zxer91
Aug 7, 2011 12:09 AM
cockerstar
Jun 6, 2008 09:37 PM
FairladyZ84
Feb 21, 2006 10:33 AM
Darius
Oct 14, 2005 09:04 PM
hndah8r
Aug 15, 2003 09:24 AM
