Clutch Fork. Pivot Ball.
Old May 12, 2006 | 02:42 AM
b1oodpaint's Avatar
This unreal transporter is what I'm working with
so i take the busted one out.
I find a way to get the new...better* pivot ball in after already nicked and oil bathed.
fork doesn't go over the ball in place.
take the ball out.
fork the fork in.
can't get the ball in.
get the ball in, fork is half cm. from destined fit.
Fork out ball in, ready to pull Mr. Tranny.
Now i'm rethinking.....maybe with slim, long needle nose I may have the back support from the retainer clip to hold the ball in place while I JAB it up to its threads..
ANYONE OUT THERE HAVE SEX WITH THIS ONE YET?
Old May 16, 2006 | 01:00 PM
b1oodpaint's Avatar
....no technical mech action in here ehy
Old May 16, 2006 | 03:20 PM
I never knew you could get that fork pivot out with the transmission still attached to the engine... so, I guess you should remove the tranny. Or use your Unreal transporter to transport the pivot ball into the bellhousing while you hold the fork in place. The trick will be to get the ball transported just right so it is screwed in tight uppon re-appearance...
Old May 16, 2006 | 07:16 PM
AZ-ZBum's Avatar
yep. a far simpler way would be to remove the transmission.
rpaquin
May 19, 2014 10:11 AM
decalservice
Aug 26, 2012 12:16 AM
metatron
Jun 6, 2012 02:38 PM
turbotim
Jul 4, 2010 07:18 PM
WolfMan
16
Mar 1, 2006 11:54 AM
