clutch
Yup, yup and yup to the replies. However, I would like to add to Passaphist that if you're not comfortable replacing the clutch yourself, you can still drive the car "clutchless" to a repair shop of your choice - no matter how far it is. I would, however, choose a shop that guarantees its work, and will also replace the throw-out bearing. Please let us know if you want more info. on driving your car "clutchless" to a repair shop or replacing the clutch yourself.
Also, I'd like to add one other thing: Is your clutch going straight to the floor, with no pressure? If so, have you checked the fluid level in your clutch master cylinder? Your problem could be just the master cylinder, which is a much easier job to "repair/replace" than the clutch itself.
Have you confirmed that your problem is the clutch itself, and NOT the master cylinder?
Originally Posted by Riz Z Speed
he just said clutch.
he didn't really specify which car.
i think i was vague enough that it'll apply to any car.
i just thought i would point it out since all his other posts were in the z31 section
Originally Posted by b300z
i know. thats why i still gave an opinion
If you haven't done a clutch before and you're doing it by yourself, it'll be a 10. You'll run into a few tricky spots along the way and you'll need to come to places ike this and ask for advice.
If you have a plan before doing it, with the right tools, and knowledge of what problems you will come across along the way, it will probaby be a 8.
For the first time, I would plan on it taking you 2-3 days. If you're not replacing the fywheel, you need to plan the time to get the old one re-surfaced. You'll also need to replace the engine rear main oil seal and the tranny mount while you're in there.
i was tired and clicked the wrong one. my bad. but yea the clutch with occationally grind when im sitting at a stop with it in gear. and if i push the accelerator past half throttle when the clutch warms up it doesnt wanna move too quickly.
me to, well.... i actually didnt need to be taught, i understood the concept and drove, lol, just needed practice to smoothen out 1st but never stalled until i was experienced, lol, over confident i guess, but yes dont sit with the clutch held down
decalservice
08-26-2012 12:16 AM
JSimpson
FS: 300ZX (90-96)
07-25-2011 10:59 PM
