ZDriver.com
-   300ZX (Z31) Performance / Technical (https://www.zdriver.com/forums/300zx-z31-performance-technical-227/)
-   -   86 reverse lights! (https://www.zdriver.com/forums/300zx-z31-performance-technical-227/86-reverse-lights-39363/)
Zsteve Mar 19, 2014 03:42 PM
86 reverse lights!
My reverse lights are on all the time, except when I turn the car off... I never experienced this one before!
Can anyone help?
Thanks!
rogerz Mar 19, 2014 04:28 PM
switch that turn them on is in the tranny if you have a stick. auto I don't know. it is stuck closed
zxguy1986 Mar 19, 2014 04:37 PM
Zsteve, I have a related prob with my '86T (my reverse lights do not work at all - bulbs/circuits are OK). Let me know what you figure out and I would appreciate the input. I have not looked into the harness hookups with my tranny (5-speed) but as rogerz says, the prob is likely there. Can't think of anywhere else it could be.. So it sounds like a good few hours of work to get in there, trace down the prob - fix it and get out again. Let me know what you do with yours. Thanks!
Zsteve Mar 19, 2014 04:44 PM
I have a 5-seed. O'boy! I have to pull the tranny? I unplugged the light's for a quick fix! I obsess when my car has probs...lol
Zsteve Mar 19, 2014 04:48 PM
I will for sure! I've had more problems with this Z than, I have had with any of the others I have owned.
zxguy1986 Mar 19, 2014 05:09 PM
rogerz didn't say - but my guess is that the harness links to the tranny would be interior - meaning inside the cabin - over the top of the tranny somewhere around the base of the shifter, in front of it or in back.
Unless rogerz sends a DON'T DO THAT msg, I would start by taking off the console and digging around. Got to be a harness link with circuits you could test. Underneath would be a major pain.
Let's wait for rogerz' input. He has obviously thought about this.... :038: and he's chronically opposed to wasted effort.
zxguy1986 Mar 19, 2014 05:34 PM
OK, but I can't throw out the baby that easy. Thrown babies cost $$$. All I really need is clean bath water. :103:
zxguy1986 Mar 20, 2014 08:26 AM
Found the reverse lamp switch in the FSM, schematics MT-2 and MT-20. Looks like you would put the car on a lift and check the switch out. It's on the side of the tranny toward the rear and it's either dead or disconnected.
rogerz Mar 20, 2014 10:31 AM
you can get to it if you put the car up on jack stands. not need to pull tranny. check for power to the switch. if no power then dive into the schematics or run a new wire. you may even find the connector hanging in the air unplugged.
Zsteve Mar 20, 2014 11:16 AM
Thanks, I looked at my other tranny, and seen the plug! So I jacked the car up, unplugged it, the lights went out!
I removed the used one and replaced it. It's working fine now!
Thanks again! 15min fix ;)
zxguy1986 Mar 20, 2014 02:06 PM
Quick fix! We all look smart again. :043:
PredatorZ Mar 20, 2014 04:22 PM
woot
Way to go, nice fix
