1989 zx Power Steering Pump Removal
Today I began the process of removing the power steering pump. I have a few questions about the removal process for a 1989 300zx.
From what I have read, there are two bolts that attach the engine lift brackets to the block. The bolt that is higher up from the ground is easy to remove. So, first question is, what is the trick to getting the lower bolt out of the bracket? My next question is this: Are there only two bolts to be removed from the mounting bracket (not the engine lift bracket) that releases the pump from the engine block? The manual that I have has some pretty crappy pictures in even crappier resolution that makes it nearly impossible to distinguish grease smudges from bolt heads. Anyone have a nice series of pictures that shows the bolts the NEED to be removed in order to remove the power steering pump? Thanks in advance |
| All times are GMT -7. The time now is 03:04 AM. |
