1986 turbo z31
I have a buddy of mine who is restoring his turbo car. He has been gutting it to make it lighter for whatever reason. And now he doesn't know which vacuum lines go where. The first question is, "Where do you run the line from the top of the fuel pressure regulator to"? And the second question, "Where do you run the two lines from the regulator solenoid to"?
Sweet thanks a lot, but what if he removed his carbon can, and the lines running in front of the intake?
Maybe... CAP THEM. :D
1986 turbo z31
OK same guy same car, now when he first turns the car on the blower motor comes on. Then when he cranks it, it shuts off and the power button won't work. So did he maybe unplug a sensor, or is it electrical. Any ideas would be greatly appreciated. :102:
kinda what happens when you just unplug things without any clue as to what they do. try reading the fsm available at xenon for free
Tell me about it I told when he started pulling things apart. But ill check it out thanks for the help:icon_super:
