Wipers and heater fan connected?
Old Mar 11, 2017 | 11:54 PM
Crashcourse's Avatar
Hi all,
Both the wipers and the heater fan on my 1987 Turbo have stopped working, are they connected to a similar control unit - because when I slammed the driver's door shut - they both worked for a second??
Fuses are good, ground leads to body seem okay, seems like a bad connection or dodgy relay/control unit to me....but where?
Any help would ne much appreciated - thanks.
Old Mar 12, 2017 | 11:15 AM
rogerz's Avatar
Grumpy & Helpful
no. probably loose connection somewhere. look for damage to fuse panel itself. check fusible links for sure. not visually take them out and use a vom on them
Old Mar 13, 2017 | 01:35 PM
Thanks for that, the wipers started working again but the heater fan is still dead. I couldn't get any power at the fuse for the blower (on the fuse panel), what feeds that?
Old Mar 15, 2017 | 05:05 PM
86tcoupe's Avatar
the blower on climate control ( you have if turbo)
the fan is inop on heat until the heater core gets to temp - then while your driving all of a sudden it blasts in your face - brilliant right ?
ecu for wipers too ,pretty sure it grounds it for the intermittent setting
Old Mar 30, 2017 | 12:57 AM
Good call Loose connections to heater blower resistor - now fixed - thanks.
300zx1990z32
May 9, 2011 07:38 AM
bdp159
May 31, 2010 06:44 AM
skupy
Nov 14, 2005 01:42 PM
swmoman
Oct 19, 2005 06:43 PM
thomas schuchat
May 25, 2003 12:41 AM
