tranny fluid
how much fluid will a z31 tranny take? cause im changing the oil and need to know thanks.
Oh young one... when will you learn? :D
http://www.az-zbum.com/information.basic.shtml PS... changing your oil is different than changing / adding tranny fluid. |
what i did when i first out fluid in that trans was get a king piece of rubber tubing and route it through the trans tunnel and up to the engine compartment, then take a funnel, shove it in there and hose clamp it to the hose, it will make life easy when filling it up.
if yours is n/a then u can take off the shifter, i believe the 6 bolts and fill it up that way. i did this with my tranny, i have the 240sx tranny in my z. it was a pain getting the proper amount in the tranny but i found that to be the easiest way.
you can do it that way?
some yes you can hoov. and hoov also fills the tranny like i do. i got a funel and some hosing, alot actually. lol. also, the fill plu is located at the level it needs to filled to, why do you think its on the side and not the top? so you add till it starts to drip out. same with the rear diff. arent car manufacturers so smart sometimes!
ok it says 5-1/8 pint wtf does that mean to me should i buy a gallon of tranny fluid or just a little bottle?
1 US gallon = 8 US pints |
ok so im going to buy a gallon and have some left over cool thanks nismo you are very helpful unlike certain ghey guys like snw and don't forget...snw!!!
i actually typed a response to this same things as nismo basically but not as kind and hit post reply, and it just kept saying "posting thread!" but it never did..... sad face :(
me to don't hold your punches snw or are you afraid?
well back on the topic of how to actually fill the tranny, because i think that my way is easiest. i clamped (with some wire twisted around) a piece of fuel line about 8-10 inches long to the little nossel on the bottle. then i put the line in the hole and squeezed the bottle with a clamp. the only down side is that you end up requiring about a pint more then you can actually get into the tranny, because you can't get the bottle upside down.
well, it was easier on my car at least, where it was a bit harder to get to it from the top |
i think im going to do it with a manual pump style thing
cheeze whiz makes great transvestite fluid
i already did it a month ago but i just hooked up the bottle up to some vacuum hose and squeezed it, it was a not fun experience
That's why I got the pump that you put onto the liter bottles of gear lube. It's been the best tool I've purchased for my Z to date.
| All times are GMT -7. The time now is 03:03 AM. |
