strange harmonic or resonating sound
Old Jun 16, 2004 | 05:44 PM
johnZboy's Avatar
Distinquished Guest
Originally Posted by hkphoto
I did all that still there..could the exhaust system be bad? or the cat...
Have you been under the car? There are other heat shields, under the car, that are known to buzz and viberate.
You will also need to get under the car to inspect the exhaust system. If you have an exhaust leak, under the car, you should see an area at the leak that has a black, carbon stain.
If the car runs okay, and you can detect exhaust flow (engine running) at the tail-pipe, chances are the cat is okay. The only thing that usually goes wrong with a cat is it will clog. Running too rich, or, too much oil blow-by will clog the cat.
You may have to get down (under the car) and dirty to figure this one out.
Artyzb29
Aug 5, 2013 08:47 PM
iamericgee
Dec 3, 2012 07:55 AM
Goofyz
Jul 25, 2007 10:15 PM
lance75_280z
Jun 23, 2003 10:11 AM
ratedZ
Aug 4, 2001 01:39 PM
