Starter Issues
Old Jul 1, 2011 | 04:48 PM
Flacster's Avatar
Starter Issues
So my starter seems to only work when it wants to. My engine wont crank at all sometimes and other times it will start right up. I can still turn on the car by popping the clutch but that's the only way it will turn on when the starter doesn't want to work. I checked the all the connections to the starter and everything seems fine. What do you guys think? Starter?
Old Jul 1, 2011 | 10:56 PM
rogerz's Avatar
Grumpy & Helpful
you need a new starter or your battery cables or your battery are in need of some help.
Old Jul 2, 2011 | 12:18 PM
omniserv's Avatar
Start by reading the FSM
Old Jul 9, 2011 | 01:52 PM
Flacster's Avatar
Just took it out and it seems that my last oil change did a number to it. The whole starter is covered in oils... I cleaned it up and see if that would do the trick and it didn't... Oh well. Just waiting now from the new one to get here.
Old Jul 10, 2011 | 09:34 PM
omniserv's Avatar
LOL, Just how does a oil change cause the starter to be covered in oil? Did you not put the filter on right or did you pour a quart of oil down the valve cover?
I think I'd be more worried by just how that much oil got on the starter than why it wouldn't start. Fix the leek first??
Old Jul 10, 2011 | 10:59 PM
AZ-ZBum's Avatar
Because the oil filter is right over the starter and it dumps out when you take it off?
Unless you turn your engine on it's side to remove the filter, I don't know how it's possible to remove the filter without getting some oil on the starter..
Old Jul 11, 2011 | 12:05 AM
Monkies's Avatar
Heh, he must go to one of those crappy oil change places.
El_Colombiano
Jan 18, 2013 03:36 PM
KasbeKZ
Sep 17, 2009 03:36 PM
vvillium3
Aug 21, 2005 09:06 AM
81 Black L28E
Jun 1, 2005 11:58 PM
AlongCamePeter
Sep 12, 2004 06:20 PM
