Spite my last post, I have a question!
Old Sep 27, 2002 | 07:49 PM
duckyz's Avatar
Re: Spite my last post, I have a question!
I haven't done that.....but is sounds like a good idea!!!!! Actually I haven't really messed with the cc much. But, Why wouldn't it work?
Old Sep 30, 2002 | 11:27 AM
Spot's Avatar
Following is some instructions I got once before, forget who from, but probably found it on z31.com.
Here is how you wire the analog dash stalk control into a digital car's ASCD.
First understand the steering controls use a transmitter in the steering wheel to communicate with a receiver located under the compartment under the luggage shelf behind the seats. This is where the hard wiring of control is.
Now you don't want to run wires from way back there to the column
switch so do this.
1) Find the brain box for the cruise control. It is inside the metal pocket behind the left kick panel above where the fuses are.
2) Now find a plug into the cruise control box. it is an 8x2 16 pin plug with one space (#12) not used. Row nearest plug lock counts across 1 to 8 and row further away from plug lock counts across 9 through 16 with 12 not used. You want to find wires for plug holes
#1 Blue with a red stripe
#2 Blue with a black stripe
#3 Blue with a white stripe
#11 blue with an orange stripe.
Then find the 2 wire plug to the clutch pedal switch. (on 5-spd cars it will be plugged into the switch, on automatics it will be hanging up where the top of the clutch pedal would be, and probably wound and taped with blue tape snug to the harness). It has 2 wires. One is yellow with red stripe the other is yellow with a black stripe. You need the yellow with red stripe wire.
The 4 wires above plus the Yellow with red are the 5 wires that you need for the column analog cruise switch. Thus splice (don't cut them, just T into side) into these five and run to the plug (you did cut the other end of the plug that the column switch plugs into off the donor didn't you?) matching the 5 colors. Now you are wired once you plug in the column switch.
Old Sep 30, 2002 | 12:45 PM
Spudz's Avatar
When you do the work can you take photos and do a tech
write up for Zdriver.com ? We need more tech stuff on cars other then the Project 300ZX TT .
Thanks,
Mike
Cingularity
Oct 26, 2013 08:42 AM
ZLover4Life
17
Jan 18, 2006 10:00 PM
turbot5
May 31, 2005 02:26 PM
zfreakracing
23
Jan 28, 2004 10:55 PM
