ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   should i buy for 500$ ? (https://www.zdriver.com/forums/300zx-z31-forums-8/should-i-buy-500%24-30526/)
banjerman Apr 19, 2010 03:42 PM
i found a 93 300zx tt with 110,000 miles it has no transmision and the turbos were takin off i think the motor is ok its an automatic car but i would do a five speed swap he wants 500$ for the car the body is great but needs paint and interior is it a good deal?
rogerz Apr 19, 2010 07:36 PM
if you gotta ask the questiion I doubt you have the expertise to make the thing work.
banjerman Apr 19, 2010 08:18 PM
well i know i can fix it with out a problem i just want to know if its worth the money?
nismo619 Apr 20, 2010 09:24 AM
jump on it ! 500 dollars for a rolling chasis is perfect start . if i had the chance i would buy it and buy a Jdm Motor off ebay and swap it in.. make sure the wire harness is still complete with the ecu. Check to see if the fuel pump works... Put in a battery and turn to key to hear the fuel pump starts to pump or turn on. your hard pressed to find a TT at all now adays all the ones i have seen are the 1990's if i had to pick i would get the 1994 or 1995 tt my 2 cents, Ken
banjerman Apr 20, 2010 03:49 PM
well i bought the car so i guess im gonna get started ;-) one thing i was wandering tho is i know it can be done but how hard is a five spped swap?
Lanoi Apr 20, 2010 04:48 PM
chisle out pilot bushing cause it the auto one, get manual pilot bushing And idk if auto has the 3 plugs like manuals . But good startfor rollings chassis. i got my na 5speed for 900 bucks lol drive but shitty. fixed now good luck
banjerman Apr 20, 2010 06:07 PM
sounds like im gonna have fun lol thx for the info
banjerman Apr 21, 2010 09:43 AM
will i need to change the rearend gearin when i swap to a five speed?
Lanoi Apr 21, 2010 10:57 AM
your gonna need drive shaft but rear diff should be okay. if u had a na and u put a tt in with tt trany the rear diff will bolt up but u get a little bad mpg. NA diffs i think have shorter gear ratios
BrettjOR Apr 11, 2013 10:26 PM
I'd Haggle. Just about any running car is worth $500. This ain't running. Offer $375 and go from there. It's worth about $225 in scrap.
NismoPick Apr 11, 2013 10:53 PM
This thread died 3 years ago... deep-6-time.
