Roasting
Old Aug 1, 2009 | 07:25 PM
mrbillishome's Avatar
Roasting
Alright ive had my 86 na on the road since march, and for some odd reason at all points in time hot air comes out of my vents. Once im running hot it does it worse , I figured it was a vacuum leak, but i cant find the damn thing. Im at a loss of figuring it out and figured i would ask for some help lol
Please and Thanks Zach
Old Aug 2, 2009 | 07:10 PM
Have you checked the coolant / heater valve?
Old Aug 3, 2009 | 06:45 PM
No. I really didnt think that it could go bad. and thanks for the input.
See but that still doesnt answer why air only comes out my defrosters no matter what i have it selected as?
Old Aug 3, 2009 | 09:42 PM
reddzx's Avatar
Originally Posted by mrbillishome
No. I really didn't think that it could go bad. and thanks for the input.
See but that still doesn't answer why air only comes out my defrosters no matter what i have it selected as?
Because that's the default setting with no vacuum pressure.
Check all the vacuum lines from the vacuum canister to the firewall. Also all vacuum lines on the heater valve on the right rear of the engine.
Old Aug 4, 2009 | 07:35 AM
Alrighty thanks and is there anyway i can get ahold of one of the vacuum diagrahms?
Old Aug 5, 2009 | 07:09 AM
reddzx's Avatar
Download a facrory service manual here.
http://www.xenonz31.com/reference.html
Old Aug 5, 2009 | 08:03 AM
once again thanks for the help.
Zach
Old Aug 5, 2009 | 03:43 PM
jrealmuto1's Avatar
put a cut off valve between the heater core hoses i did it and it works
Old Aug 8, 2009 | 12:22 AM
kittyz's Avatar
i have the same problem. lemme know what yah did.
Old Aug 10, 2009 | 12:10 PM
Alright i think my vacuum tank is bad but i ran a new vacuum to the water **** and after a few pumps of the gas it has enough to shut it, for the interior actuators the line running to them is bad on dash side and haven't had time to pull the dash and find it/.
Old Aug 10, 2009 | 05:46 PM
kittyz's Avatar
good luck. and post pics if yah can.
Old Aug 10, 2009 | 09:36 PM
I've pulled the dash out of my car hundreds of times so no need for luck on that lol. Its just tracing the vacuum line that will give me problems.
Old Aug 19, 2009 | 03:02 PM
kittyz's Avatar
mine doesnt run so im not worried bout mine... yet.
Old Sep 3, 2009 | 01:39 PM
SloppyGoat's Avatar
Wow, you're brave. I've never pulled a dash out of any car I was going to have to put it back in, and hope I never have to. I'm sure that's a real bitch of a job.
Old Sep 4, 2009 | 07:47 AM
reddzx's Avatar
It's not that bad of a job. Just go to Zbums site for a write up on how to do it
Old Sep 4, 2009 | 07:48 AM
reddzx's Avatar
Step by step directions on how to do it.
http://www.az-zbum.com/repair.dash.removal.shtml
Old Jul 30, 2010 | 04:15 PM
robertporter24's Avatar
Check the blenddoor actuator under the dash. I have the same problem and that was the suggestion made by the guys at ZFever in Tampa.
Old Aug 2, 2010 | 03:47 PM
SloppyGoat's Avatar
I still doubt it would ever go back together right, without having to remove it again and fix something, or reroute something that got pinched in the process. It's a horrible car to have to work inside of, with so limited space!
