Redoing My "Z"
Old Oct 5, 2001 | 11:40 AM
Spot's Avatar
Re: Redoing My "Z"
I am flipping down the liscense plate to go in front of the air dam.
Be careful not to block what little bit of air already gets into the intake. Also take into consideration that if you do this, you may also be blocking the air flow through your radiator - you may end up with overheating problems due to not enough air flow.
I don't know anything about all that stereo stuff, but if it draws a good bit of power, you may want to consider putting a Maxima alternator in your car in place of the stock one. Maxima ones from 89-92 are supposed to be a direct bolt in, but has a smaller diameter pulley (meaning it makes more power at lower speeds). it's rated at 90 amps versus the stock 70 amps that is one your Z now. Supposedly the wiring plugs right in, and you just have to remember to get a smaller alternator belt since your stock one will be slightly too long.
With regard to keeping all your goodies that you plan on installing (as opposed to someone stealing them...), check the regulations regarding tint on the rear windows. Here in Tx, we can have limo tint on the back - I have that on my '86T, and can assure you that it'd take a would be thief about 15 minutes to be able to tell what you even have back there cuz it's so dark. If you can get your hands on a rear cargo cover (like came stock on ones with leather interior), then get it (don't forget to get the clips for it too) and install it in your car. Be aware that 2+2 cargo covers and 2-seater ones are DIFFERENT! They are NOT interchangeable, so verify this before you yank one from a junkyard or anything. To complete it, you will also need the rear trim piece on the hatch that covers the window wiper motor back there, as the cargo cover cars have an extra piece riveted to that panel, otherwise you'll have a gap where yours is missing.
Good luck with your mods.
Spot
helplesszkid
Nov 26, 2006 06:52 PM
Aphrodite
Jan 20, 2006 05:17 PM
Texaz
Oct 29, 2005 11:01 PM
