ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   recalls (https://www.zdriver.com/forums/300zx-z31-forums-8/recalls-3792/)
danielschoenwald Oct 12, 2002 08:50 AM
recalls
What were all the recalls on an 84 300zx n/a.
AZ-ZBum Oct 12, 2002 09:55 AM
Re: recalls
go to http://z31.com and read the section entitled Recalls/TSBs. The only one you will ever be able to get is the one about the fuel injectors, so it's not even worth looking at.
http://zbum.nissanpower.com
danielschoenwald Oct 12, 2002 02:38 PM
Re: recalls
Do you think that i will be able to get the one about the headlight switch????
AZ-ZBum Oct 12, 2002 02:59 PM
Re: recalls
Nope. Again, <font size="+1">The only one you will ever be able to get is the one about the fuel injectors</font>
BreakbeatBob Oct 12, 2002 03:19 PM
Re: recalls
Go and ask your local Nissan dealer if they can switch out your headlamp switch for free, let us know how long they laught at you. Do you read the entire responses before you reply?
<font color=blue>.:Robert:.</font color=blue>
AZ-ZBum Oct 12, 2002 05:08 PM
Re: recalls
I don't know if they'd laugh at him... probably more of a bunch of dumb blank stares. Then, when he left, they'd all get together and laugh.
danielschoenwald Oct 12, 2002 08:08 PM
Re: recalls
There was a recall on 84s to replace the headlight switch on the steering column because it was manufactured with corrosive grease, which corroded the contacts and rendered one or both low or high beams inoperable. You should still be able to get and Dealer to replace the switch for free. that was off of z31.com
XXtacy Oct 12, 2002 09:23 PM
Re: recalls
I think most of the recalls had expiration dates to them. All except the injector thing, because that was a safety thing (being it could burn your car to the ground... while you were in it)
AZ-ZBum Oct 12, 2002 10:07 PM
Re: recalls
First: I already told you that the only thing you'd get done would be the injectors if they hadn't already.
Second: TSB is not the same as a recall.
Finally: I seriously doubt your car was <font size="+1">MANUFACTURED FROM JULY TO SEPT. 1983</font>
Now, next time you ask a question, I suggest you try READING THE ENTIRE MESSAGE.
Now, as for my experience:
I've had one of my Z's for over 8 years and 110,000 miles (it now has 215,000 miles on it). I stopped taking it to the shop to get worked on 6 year ago because I was in college, and I would rather have spent money going out than giving it to someone else for doing the work I could just as easily do. There is nothing YOU can possibly tell me about these cars that I don't already know. And there's probably still lots I have to learn.
BreakbeatBob Oct 13, 2002 01:11 PM
Re: recalls
Yeah, AZ has a lot of ZX's compared to most people, and he is very smart when it comes to working on them.
My favorite
Again, goto a Nissan dealership and tell then that they should replace your headlamp switch since its a 'factory defect' and see what happens; or even better, do it yourself.
CaliZ31 Apr 2, 2003 12:37 AM
injectors
AZ, is there anyway that you can tell if the injectors were already done? Sorry im new to the Z world and I do smell gas from time to time. Could it be the injectors or something else? BTW I have an '84 blue Z.
Thx in advance
86ZXTurbo Apr 2, 2003 02:49 AM
I called my local nissan dealer and gave them my VIN and MADE them check for the recall work done on the car in their computer. they were like what the hell are you asking for a car this old but they did as I kept pushing them, and they were able to tell me....try that and let us know.
Spot Apr 2, 2003 07:36 AM
Re: injectors
Thx in advance
Call 1-800-nissan1 and they can check for you - have your VIN handy. If it's been done already they can tell you who did it , when and how many miles were on the car when it was done. If it's been done, then try this - look at the injectors and make sure the area around each is dry. Then run the car for a while and then look again at the injectors to see if they look wet. If so, it could be leaking o-rings. You can get o-ring seal kits for them from o-reilly's for about 2-3 bucks for each injector. If you replace them, go ahead and do all of them while you're there. Also take note to replace gaskets for anything you have to take apart to get to them (you should NEVER reuse gaskets - that's just begging for trouble).
Spot
