ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   POWER WINDOW (https://www.zdriver.com/forums/300zx-z31-forums-8/power-window-1634/)
84zxturbo Mar 23, 2002 02:12 PM
POWER WINDOW
MY PASSENGER SIDE WINDOW GOES DOWN BUT WILL NOT GO UP BOTH SIDE SWITCHES WILL NOT ROLL IT UP. IF I TURN THE WIRES AROUND IT WILL GO UP BUT NOT DOWN....PLEASE HELP
Red_October Mar 25, 2002 02:24 PM
Re: POWER WINDOW
replace the switch
Spot Mar 27, 2002 10:35 AM
Re: POWER WINDOW
could be your motor is taking it's dying breaths. find a good one at a junkyard - the dealer wants an enormous price for them. of course, try cleaning the switch contacts first as that would be the easiest/cheapest fix.
Gricebrner Mar 28, 2002 02:55 AM
Re: POWER WINDOW
I'm parting an 85NA; if you need the switch or the motor, let me know Z ya, Steve
Gricebrner@aol.com
Skaitan Apr 15, 2002 03:25 PM
Re: POWER WINDOW
It could also just be one of the switches, I had that same problem, and the contacts on the "up" side of the switch had bent and loosened over the years and just weren't contacting, so if you pry up the switch and just bend all the tabs in and make sure all the pins are making contact, it may help!
The Beast is back and badder than ever!
NavyZguy Aug 29, 2002 09:42 AM
Re: POWER WINDOW
It's a switch. If it was the motor, then it wouldn't work at when you switched the wires around. Nice trouble shooting so far....good luck!
