Play times over
Old Feb 11, 2006 | 06:17 AM
WolfMan's Avatar
Play times over
All right, I need a nissan dealers email. I have no Idea if my car has had the injectors changed or not. I was talking with a nissan dealer in Germany, he said it was not a fuel problem. I said that I checked the computer and have no Idea what its trying to tell me. He then proceded to read the codes. No problem right? WRONG, he did not mark where it was initaily set, so now it still has the problem and I think it is rougher running now. so, anyone have an Idea why a cylynder will not fire? That is the problem I think I am having with it, thats why it is rough until I give it more gas. There is also a high buzzin under the hood, only rare during Idle and can be heard, after reving the engine. Plz help me with this, its really starting to hurt my head.
Old Feb 15, 2006 | 11:04 AM
WolfMan's Avatar
well, obviously nobody has a clue, or they all hate me...
to update my prev. post. I got the engine codes, there are 4 total.
14, 34, 23, 42.
14 = vehical speed sensor? I unpluged the TPS. this code came on, so I put it back on and the code disappeared.
34= Det. sensor is open or shorted. how do I fix that?
23= idle switch circuit is open.. is that normal?
42= Fuel Temp. sensor. How do I replace that?
ps, germans did not have these codes meanings, I had to look them up, so if you know they are wrong, plz let me know asap.
Old Feb 15, 2006 | 11:25 AM
FreeLanceBum's Avatar
42
The fuel temp sensor is on the front of the fuel pressure regulator (located on the front of the intake plenum).
Theres a wire connection on it, just pull it straight off, then unscrew the temp sensor and put a new one on.
Old Feb 15, 2006 | 12:16 PM
WolfMan's Avatar
sweet thanx alot, hopefully that does the trick.
Old Feb 15, 2006 | 12:45 PM
AZ-ZBum's Avatar
the location of the code reader screw will not affect driveability of the car. there should be no difference in the way the car performs.
Old Feb 15, 2006 | 01:37 PM
34
If I recall correctly, the sensor in located bottom of the block, passanger side.
Have to get under the car for easy access. It's fairly small, don't get it confused with the oil pressure sending unit, which looks like a little can screwed into the block with 1 black? wire coming out of the end.
Check if the wire harness is still attatched, if it is, you prabably need a new sensor.
Old Feb 16, 2006 | 08:00 AM
WolfMan's Avatar
thnx for all the info. one question, why does the Haynes say that the position of the idle screw has to be marked? either way, i need to replace these sensors. when this will be done, there is no tellin. I just had 2 wisdom teeth pulled, kinda druged up. but as soon as I do those sensors I will write up the status of the car.
thanx again all
Old Feb 16, 2006 | 10:40 AM
AZ-ZBum's Avatar
later models (87+ I believe) actually had multiple settings for diagnosing issues. otherwise, it's full counter clockwise or full clockwise.
Old Feb 17, 2006 | 01:31 AM
WolfMan's Avatar
well, on the computer itself, it says idle setting. and if you turn it all the way clockwise it says diagnostic. thats whay I was kinda mad, I have no idea where it is suppose to be set. I made my wife really mad today..hehe, I am already recovered from the teeth pullin, my jaw is just a lil sore and thats all. already eating real food!! enough about that, thanx everyone who replied to help me out with this issue.
wolfman out
maxtorque
Sep 16, 2009 06:52 PM
Ratfink
Aug 6, 2008 02:54 AM
WildmaN
Jul 28, 2007 04:17 PM
thxone
Feb 24, 2007 04:00 PM
81 Black L28E
Jun 13, 2005 08:32 AM
